Quick question on channel list updating
  • Kenneth2013
    • Jun 2013
    Hi there, I am currently using a skybox f3. The way I input channels are like the main stream box in the UK, i.e. 101 for bbc1, 501 news channel. I would like to use AJS channel list, will this remove my channel input that I already have? Or will I be able to use his list and continue to have this channel input but have the channel numbers he has? or will his channel list only work through the faves way?
  • DW190
    • May 2012
    • 1263
    As the F3 list starts at number 1 that is where BBC1 will be. Using the Favorites to find channels is the easiest.
    • worcestersauce
      • 136
      I wanted to know this too............does AJs list overwrite your existing faves list or does it run along side the other faves lists you already have ???
      • mahrkpat
        • Jun 2012
        • 510
        When ever you put in a new channel list it will overwrite the old one.
        • willbert
          • May 2013
          • 11
          Possibly the easiest way to do what you are wanting to do is get ajs list onto box, then do a channel scan, then when finished you will have a hell of a lot of no name channels bump them to channels 1-100 then block them and skip them in settings then build your list from there. To get the most upto date channel numbers download the sky+ app from the app store/play store and use the channel numbers on there to build the list. Have to admit it will take hours but when finished it should look great also you will still have ajs list in favourites so a win win situation
          • worcestersauce
            • 136
            I'm a newbie to the F3, working great but the odd one or two channels missing. I know I have to change the channel list (going to use AJ's) but have never done a change of list so far.
            There must be a guide on here somewhere on HOW TO..(as i dont want to wipe what i already have).........if someone would be so kind to point me in the right direction as i have some spare time to have a go today..........much appreciated if possible
            Thanks guys and gals, keep up the good work
            • willbert
              • May 2013
              • 11
              Make sure you on latest firmware go here to get it Download / Software / Skybox F3/F5/M3_Shenzhen Yojia Technology Co., Ltd. then update box, then delete all channels and add ajs list and you should be sorted
              • worcestersauce
                • 136
                Its the adding AJs list I was asking about matey, is that done via usb stick then?
                • willbert
                  • May 2013
                  • 11
                  Yes but make sure your on latest firmware as you may end up with file mismatch when trying to update, get the latest firmware sling it to root of sd card/stick then update it then delete all channels when finished then add ajs list, all done with files on root od sd
                  • P&D
                    • May 2010
                    • 2686
                    Yes mate just update the channel list via usb
                    no need to update the firmware unless you want to
                    if you are going to update the firmware make sure you know what you are doing & back the whole of your box up onto a usb stick before doing anything
                    • worcestersauce
                      • 136
                      Cheers P&D, still havent tried it yet, too scared to lose everything else .......suppose its easy enough, frist time jitters and all that
                      • P&D
                        • May 2010
                        • 2686
                        Its easy mate
                        download the latest channel list file onto usb (at the bottom)
                        plug the usb into the box
                        press menu goto delete all (this is the old channel list) delete them
                        goto upgrade by usb
                        upgrade mode press sideways on the remote select (misc file)
                        go down to select & update
                        highlight 1 TP_prog.dbs press ok
                        the press the yellow button wait till loaded
                        then exit
                        then reboot
                        job done
                        • worcestersauce
                          • 136
                          Originally posted by P&D
                          Its easy mate
                          goto upgrade by usb
                          then exit
                          then reboot
                          job done
                          At last, the newb guide i was hoping for, will have a go tomorrow and i'm sure the thanks will follow, cheers P&D
