Sky sports 2 and box nation
  • Stev0
    • May 2013
    • 5
    Just wondering if someone could help me out. A few weeks ago everything was working ok.
    Then I noticed box nation and sky sports 2 were blank.
    I've updated with AJ Chanel list but sti got the same problem.
    Sky sports 2 has now been replaced with sky sports ashes but no picture
    But box nation is still nothing aswell.
    On a plus thou bt sport 1 and 2 are now there
    Thanks in advance
  • michelle8
    • Dec 2012
    • 10
    hello m8 read your post delete all channels and do a rescan all will be ok then
    • Stev0
      • May 2013
      • 5
      Hi m8, so I need to delete the Chanel list I've just updated, I don't actually know how to re scan
      • Dazzle1
        • May 2013
        • 11
        You have to first delete the channel list. Then perform a re-scan and then update your channel setting to AJ list. Via the menu
        • skunk1111
          • 55
          update you sat xlm and rescan
            Pray tell how you do this on an openbox/Skybox seeing as they are a closed source receiver, sat.xml files relate to Enigma1/2 receivers
            • Stev0
              • May 2013
              • 5
              I found out this fault was due to bad lnb, plugged box in to a friends dish worked perfectly
