skysport hd2 / ashes not working? skybox f3. how do i change frequency and what to?
  • wakkaday
    • 148
    please advise?
    many thanks
  • boylan
    • Oct 2011
    • 128
    Update youre channel list, to AJs http://www.digital-kaos.co.uk/forums...ularly-260273/ or SATTV5's http://www.digital-kaos.co.uk/forums...thread-350451/
    • robo1804
      • Mar 2010
      • 13
      Hi, having the same problem both channel list ok but sly2(ashes)hd not clearing. Any ideas??, Regards
        If your getting a signal and the channel list is OK then its something else 'Gift' wise which cannot be discussed
        Regards
        • Dazzle1
          • May 2013
          • 11
          I read this somewhere and it's very helpful. If you want to add one channel which no longer available. Search for the channel id on lyngsat.com, find the freq sp (sky sports ashes 11720)
          Then on the skybox go to menu -> TP setting -> scroll to the freq 11720 -> search that freq and any channel now under that freq will appear at the end of the channel list.
            WOW! as simple as that if only every new member we had showed a bit of ingenuity and sorted there own problems we would not have New Threads started about something as simple as a channel scan, Well done Dazzle1 for not joining the spoon fed brigade.
            Regards
            • DW190
              • May 2012
              • 1263
              Regards
              And well done DW for posting what he read.
              • ajax2061
                • 395
                Also you might find if you swapped from one channel list to another by someone else you might get none working channels, what I do to *TRY avoid this is every time I update the list is to delete the channel list in the menu first, this should not delete the names on the favourite sections and then update.
                *does not always work
