Skybox f5 set up and instructions
  • waynebo1975
    • Jul 2013
    Right guys im not going lie i know absolutely piss all about these boxes but i bought one anyway
    ordered my wifi dongle from ebay so they are on there way.i take it you have to flash the box some way.latest fireware etc?/
    do i have to subscribe to the lines to get the channels??
  • andy4
    • 1125
    download shady's tutoral http://www.digital-kaos.co.uk/forums...-guide-257009/ you should have no probs as for lines your not allowed to talk about this on DK
    google for any info you need
    WIGAN ATH the BLUE BRAZILIANS
    DWSTADIUM the theatre of SCREAMS
    <<<<--------if i've been helpful hit the Thanks button
    • waynebo1975
      • Jul 2013
      cheers man
      • Rodnorris
        • Jun 2013
        Skybox f5 only loads to 90
        Was watching my skyf5 box last night just went off , came back on about an hour later but only loads to 90 only had it about a month , anybody have any ideas how to get it working again , any help is much appreciated thanks .
        • andy4
          • 1125
          sounds lik you may need to reflash your box have a look ere http://www.digital-kaos.co.uk/forums...-cable-233298/
          • P&D
            • 2686
            Anther box bit's the dust (sorry Rod) but this is very common with the wong tong box's
            • mahrkpat
              • Jun 2012
              • 510
              If it is loading up to 90 then I do not think it is a firmware issue but a hardware issue, disconnect your satellite cable and see if it manages to completely boot up if it does then you might have a easy solution check the connectors of your cable and make sure the cable is not shorting also check the cable to make sure it is not frayed anywhere.
              Good Luck.
