Hi, tried using the S/W upgrade by USB usign bootloader method, but am get
[QUOTE=sattv5;2048176]
Originally posted by DW190
As the box wont load past the ON there is no way of getting the to the menu to upgrade by USB.
Have you contacted your supplier? He may have a loader. QUOTE]
Luckily the sunplus based receivers (X5 & F6) can be recovered using the usb port
OPENBOX X5 & Skybox F6 Recovery
1. Format USB drive to FAT32 file format
2. Create a folder named "recovery" on the USB drive
3. Copy KD_P9000E_HD.bin file to the recovery folder on the USB drive.
4. Connect the USB drive to the USB Port on the satellite receiver.
5. Turn the power on the satellite receiver while pressing the OK button on the front panel.
6. Keep the OK key pressed until showing Lxxx message on the LED of the front panel.
7. On the TV screen it should show that the software is updating by the USB drive.
8. The STB should now restart hopefully all should now be working
I have included the firmware for the X5 & F6
Hi, tried using the S/W upgrade by USB usign bootloader method for an F6 and firmware above, but am getting 'Check Error, Try Again' at 100%.
Any tips?
Any tips?
Just try again.All i can tell you is I did the above to an F6 a week ago and it works.
mickzer
