5% snr on sly sports 3 hd on Skybox F5
  • andy91
    • 3583
    As the title says has anyone had this issue? Tried different firmware and still the same so basically no channel yet all others are fine, Andy
  • DW190
    • May 2012
    • 1263
    Would generally look to dish alignment but if its only on one channel its a little strange. Have you another box to try to eliminate the dish setup.
    • andy91
      • 3583
      Yes Dreambox 800hd works perfectly so not dish all cabling, Andy.
      • cgscott
        • 3513
        Remember to check other sky sports 3 mate as that may be a duff channel
        Patience is a virtue.
        • andy91
          • 3583
          The box is my mates so im guessing it could be a duff channel but its from latest channel list so expected it to work, Andy
          • cgscott
            • 3513
            Probably find if you scan the channel frequency in for that channel it will pull in the proper channel
            • DW190
              • May 2012
              • 1263
              One thing springs to mind here.
              F 5
              • andy91
                • 3583
                Not got a Skybox so bit of a novice set it up for a friend, any reason why in menu some of the options were greyed out in the sat section? Andy
                • DW190
                  • May 2012
                  • 1263
                  Go into sat list and make sure sats are ticked at the far left of the sat line details
                  • andy91
                    • 3583
                    Pretty sure it was ticked but not certain. Lost connection when I tried Sly sports 3 and was a pain to connect again,crap F5 boxes Andy.
                    • DW190
                      • May 2012
                      • 1263
                      • andy91
                        • 3583
                        Just seen monsterquads post its the same after Ajs channel list when I get chance will check it out, Andy
