hi im wanting to save all info whats on my skyboxf3 just in case anything should go wrong with it how do i do this
sky box f3 help
Make sure your USB is plugged in then navigate to Menu > Tools > Dump by USB > Change Dump Mode to "Misc File" > Click on "Select and Dump" > Select "TP_PROG.dbs" so it has a tick next to it then press yellow to "Dump onto USB", this will backup your channel list. To backup your Server/Gift whatever you want to call it just select the "CCcam.cfg" file instead of "TP_PROG.dbs". To backup your whole image "Dump to USB" before changing the dump mode. The required backup should now be on your usb stick, make sure to move it to your pc or be careful not to delete it.
this should help buddy
ps make sure you save it on your computer then put the info back on your box !Last edited by scotty1965; 1 August, 2013, 11:33.
