Issue with f5 - some channels freeze after a few seconds
This topic is closed.
  • Danb
    • Apr 2012
    • 9
    Just got an f5 installed, certain channels freeze after 2/3 seconds, but yet some are ok.
    Ie sky sports 3 and f1 work but others don't and freeze
    Any ideas?
    Using latest software and latest aj listing
  • darcu5
    • Jun 2011
    • 944
    Check dchp is turn on in network setting, check the signal strength on the channels that freeze by pressing info three times, it may also probley an overloaded crap server u are using. And that wil probs see this thread being locked as you ain't allowed to talk about them on here. If it is the latter then google will point you in the right direction
    • P&D
      • 2686
      Any ideas?
      Are you using Wifi or Ethernet cable ??
      • Danb
        • Apr 2012
        • 9
        Isn't the dhcp as it doesn't work when it's set to off, but works when set to on.
        It's not the server as tried 2 other older openbox on same server and that's fine.
        Signal drops to around 15-20% when it freezes
        • Danb
          • Apr 2012
          • 9
          Ethernet cable
          • P&D
            • 2686
            What firmware are you on ???
            Menu / system info
            • darcu5
              • Jun 2011
              • 944
              If signal drops then it's not Internet related. It is either the box or the dish or the wire between dish n box. Different firmware may sort it, if other boxes work fine with the same channel list etc on it then that just points to the box being the problem,
              • Danb
                • Apr 2012
                • 9
                Main chip - Ali3601hd
                Software - 3601hd 27/3/13
                Tried few different software but same issue.
                Also tried it at a different household so different Internet/dish and same issue
                Beginning to think its sonething with the box
                  If FTA are working OK then thats as far as this discussion can go on the matter any words such as Scrambled,Freezing,Pay Channel then use Google
