Cwaite Sky Numbered Channel List **Discussion** Thread
Just wanted to say a very Merry Christmas to all Digital Kaos readers and staff, thanks to all for downloading the CWAITE Sly numbered channel list, we will be back with more updates in the new year (sometime after 6th Jan 2016).Leave a comment:
@Michael25 you can get the TP_program.dbs from this link, just unzip either the general one or use the nonadult one.
The latest CWAITE (previously sattv5) Sky Numbered Channel Lists can be found here. (http://cwaite.dyndns.tv) We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite RemoteLeave a comment:
Hi Everyone I'm new to this I used to have a dreambox but have just purchased a openbox v8. Where do I obtain a TP_prog.dbs channel list from plus ~~~~~.ftg file.Leave a comment:
Big thanks for the quick correction to Sly Sports, was also having issues with that channel.Leave a comment:
will try this later tonight.
thanks for all your help , much appreciated.Leave a comment:
This is how i setup the channel lists up & never have a problem with either list cwaties/Aj's
done 3 this week for the familyLeave a comment:
I didn't reboot after channel list delete , just loaded cwaites list straight away. I'm guessing that's my problem ?Leave a comment:
Menu delete channel list reboot the box
once the box restarts you will have NoCH on the front of the box
Then load cwaites list then reboot......
What firmware is on the box
menu/system infoLeave a comment:
If you mean delete all channels in the channel edit tool then yesLeave a comment:
Trying to sort a problem out with a friend's skybox v8s. He had been downloading from ajsat and was never getting skysports 1,2,3 or sky premiere (strange that he was getting premiere +1) . I then installed cwaites prog list and it recovered skysports 1 & 2 but still missing ss3 and premiere ?
any help very much appreciated.Leave a comment:
Yes have a word with both yours and your Dads providers, its strange that they have gone off recently as none of these channels have ever changed (Frequency or SID), at least not changed since I took over the list in August 2014.Big thanks for all your help much appreciated like i said everything has been ok until this list but i can switch channels in editor when new lists are available,by my man do you mean my line provider cause my dad has a different provider to me but is having the same problemLeave a comment:
It looks like your man has setup his system to AJ's Channel list, I am reluctant to change the channels on the main channel list as these SID's appear to be the main SID's used by Sly, and for the majority of people they seem to work without a problem, I have therefore added the frequencies and SID's as Alternatives and can be found on the following channel numbers
1260 Sly 1 (Alt)
1261 Sly Sports News HQ (Alt)
1262 Sly Sports 1 (Alt)
1263 Sly Sports 2 (Alt)
They are also added to the end of the Favourites, these Alternative channels will remain on Future Channel list updates.
If you can speak to your men and ask them to make adjustments to allow his magic to work on CWAITE's list as well as AJ's then that would help a great deal.Last edited by cwaite; 16 December, 2015, 13:27.Leave a comment:
Leave a comment:
