AJ's Sky UK Channel List **Only** Thread - Updated Regularly
  • DeejayAJ
    • Feb 2012
    • 402
    AJ's UK Channel List
    • HD swapped.
    • OCD order (TLC, +1, +2 etc.)
    • Ordered so favourites aren't essential.
    • Duplicate & dead channels removed.
    Favourites
    1. Entertainment
    2. Lifestyle
    3. Movies
    4. Sports
    5. News
    6. Documentaries
    7. Kids
    8. Music
    9. Shopping
    10. Religious
    11. International
    12. Gaming & Dating
    13. Specialist
    14. Adult
    15. Regional
    16. FTA
    17. Sky Anytime
    18. HD
    19. Sports Interactive
    20. BBC Interactive
    21. Information
    22. Bonus
    23. Box Office
    24. Irish
    25. Testing
    Check post #2 for a tutorial, FAQ & update log.
    Backed up at - AJsat.co.uk
    Updated 8/6/16
  • DeejayAJ
    • Feb 2012
    • 402
    Update : 2/4/16
    Racing UK HD
    True Crime
    True Crime +1
    CBS Action
    Showcase +1
    Made in Bristol
    Made in Cardiff
    Made in Leeds
    Wellbeing
    Talking Pictures
    Keep it Country
    The Word Network
    Faith Channel
    KICC TV
    Ahlebait TV
    Hum Europe
    Channel S
    Update : 5/3/16
    Channel 5 HD (channel 66 because it isn't FTA)
    BT Sport 1
    BT Sport Euro
    Horror Channel
    MTV Music +1
    Showcase 3
    OHTV
    Al Jazeera
    Faith Channel
    Wellbeing
    Channels 24
    TV One
    Ahlebait TV
    HUM Europe
    KICC TV
    ATN Bangla
    Bangla TV
    Update : 13/2/16
    RT? 1
    RT? 2
    RT? Jr
    TG4
    Oireachtas TV
    FAQ
    How do I put this list on to my box?
    Firstly, before any upgrade you should always backup! Once you've done that;
    1. [*=1]Unzip AJ's List XX-XX-XX.zip with a program such as winrar & place the TP_PROG.DBS file onto the root of your USB drive.
      [*=1]In the Openbox menu delete your current channel list by going to the "Edit Channel" tab & selecting "Delete All".
      [*=1]Staying in the menu navigate to the "Tools" tab then "Upgrade by USB", change the upgrade mode from "Image File" to "Misc Files" then "Select & Upgrade" & select "TP_PROG.DBS" then press yellow, if all done correctly it should begin to upgrade.
      [*=1]Once the upgrade has completed restart your box & voil?!
    How do I backup?
    Make sure your USB is plugged in then navigate to Menu > Tools > Dump by USB > Change Dump Mode to "Misc File" > Click on "Select and Dump" > Select "TP_PROG.dbs" so it has a tick next to it then press yellow to "Dump onto USB", this will backup your channel list. To backup your "gift" just select the "~~~~~.cfg" file instead of "TP_PROG.dbs". To backup your whole image "Dump to USB" before changing the dump mode. The required backup should now be on your usb stick, make sure to move it to your pc or be careful not to delete it.
    Will updating my channel list effect my server settings etc?
    No, your channel list is the only thing that's affected but it's always wise to backup just in case as problems can happen. This is for channel lists only, firmware updates erase everything.
    Why aren't the channels in the same order as my Sky box?
    I put the channels in the order that I feel is the most efficient & simplest to use. There are plenty of Sky ordered lists if that's what you prefer, Sattv5's list is the best I've seen (LINK).
    Why are my favourites not named correctly?
    If you're using my channel list for the first time, the favourites will likely not be in order. To put them in order, go into the menu and "reset to factory settings" and then reboot. Your other settings shouldn't be effected but please backup/"dump to usb" your ~~~~~.cfg file first just in case anything goes wrong,
    How do I edit the order of the favourites?
    The only simple way would be to use SetEditHD100 (LINK), the program isn't free but It'll let you make 25 changes before it stops working.
    The file is corrupted, not found or won't download.
    The most common cause is an incorrectly named file. This usually happens if you've downloaded more than one file. As the files are all named the same, the computer will automatically rename the files to differentiate between them. To fix it, open up your USB stick and rename the file exacly TP_PROG.dbs . If you don't have file extensions showing then just name it TP_PROG or you'll end up with the file actually being named TP_PROG.dbs.dbs and that won't work either.
    If that doesn't work then try downloading the unzipped file from my site - ajsat.co.uk, if it still doesn't work then try a different internet browser.
    Does this list have 'X' channel?
    The list should have every channel including all Radio, Box Office & Red Button services.
    How can I make my own list?
    Firstly you'll need a channel editor, PVR800 editor is the simplest option, I've attached the .DBS version to the bottom of the post. Then you'll need a list to edit, either mine/someone else's which would be the best option or you could do a fresh scan yourself & edit the backup up file. The satellite info you need to edit lists is at KingO**at. It looks complicated but it's pretty self explanatory, check out other specific threads on the subject or ask questions in this one if you have any issues.
    Which boxes is this list compatible with?
    Skybox/Libertview/Openbox S9, S10, S11, S12, F3, M3, X3, F5, F5S + more. The X5/F6 have their own list here, the S16 can use this list but it'll need exporting with the editor as .udf instead of .dbs.
    • DeejayAJ
      • Feb 2012
      • 402
      Update : 25/06/12
      At The Races
      UMP Stars
      Fox News
      Sky Poker
      ABP News
      S4C
      Ahlebait TV
      Buzmuzik
      OHTV
      Really
      Life OK
      BEN
      EWTN
      Vintage TV
      Let me know if I've missed anything!
      • DeejayAJ
        • Feb 2012
        • 402
        Update : 26/06/12
        Star Plus HD
        History
        History +1
        Nat Geo
        Nat Geo +1
        Nat Geo Wild
        Nigezie
        The Dept Store
        Various Adult channels
        • DeejayAJ
          • Feb 2012
          • 402
          Update : 7/7/12
          BBC Olympics / HD
          Alibi HD
          Comedy Central Extra
          4seven
          HiTV
          Africa Channel +1
          Sky Summer / HD
          Nick Junior / +1
          Nicktoons / +1
          High Street TV
          Various adult channels
          • DeejayAJ
            • Feb 2012
            • 402
            Originally posted by kman999
            Thanks as always great work, just wanted to check on the channel with Adult I have noticed that Sky Showcase/Sky Summer is at the top of the Sports Favourite, is it just me?
            Thanks, fixed! Can someone test it before I add it the main post.
            • DeejayAJ
              • Feb 2012
              • 402
              Update : 23/7/12
              Last 8 Olympic HD channels
              Eurosport 3D
              Massive R&B
              Clubland TV
              BBC Three
              Geo TV
              Can someone try them & let me know they work so I can update the OP? Thanks.
              • DeejayAJ
                • Feb 2012
                • 402
                Update : 01/08/12
                All Radio Stations
                Removed Empty Adult Fav from the No Adult list
                Fixed Default Data Base
                • DeejayAJ
                  • Feb 2012
                  • 402
                  Update : 10/08/12
                  Removed SD Simulcasts
                  Studio 66 TV 1 - 4
                  Speed Auction TV
                  ARY Digital
                  Aaj Tak
                  E!
                  • DeejayAJ
                    • Feb 2012
                    • 402
                    Can someone that can access 4.8e please test this football list.
                    • DeejayAJ
                      • Feb 2012
                      • 402
                      Update : 28/08/12
                      TCM HD
                      Eurosport 2 HD
                      Sky Showcase HD
                      Paralympics HD
                      The Deal Channel
                      Nick Replay
                      Nick Junior
                      Nicktoons
                      Horror Channel
                      Africa Channel
                      Various Regional
                      Various Adult
                      • DeejayAJ
                        • Feb 2012
                        • 402
                        Update : 01/09/12
                        TCM
                        Bio +1
                        Various minor changes
                        • DeejayAJ
                          • Feb 2012
                          • 402
                          Update : 14/09/12
                          Rishtey TV
                          Fashion One
                          Zee Caf?
                          Paralympics
                          xxXpanded TV
                          • DeejayAJ
                            • Feb 2012
                            • 402
                            Minor Update : 30/09/12
                            Sky Atlantic +1
                            Klear TV
                            + Minor Changes
                            • DeejayAJ
                              • Feb 2012
                              • 402
                              Update : 09/10/12
                              Sky Movies 007 HD
                              Nickelodeon +1
                              Nick Junior +1
                              E! HD
                              PTV Prime
                              Channel S
                              Madani Channel
                              NTV
                              Channel i
                              ATN Bangla
                              Noor TV
                              Channel 9
                              HiTV
                              UCTV
                              Gospel Channel
                              Geo TV
