Video sender transmitter with skybox
  • evoy2k2
    • Aug 2013
    • 10
    Just got myself a skybox f5 hd. I had sky prior to this and had a magic eye so i could watch tv in the bedroom. Can i get a video sender to work with these skybox's,as the one i had with original sky box doesn't work anymore. If there is a video sender i could use, what one would be best ?
    Any help apprecited guys
    evoy2k2
  • digicon
    • 8261
    If the cable for the Magic eye is still in place and is accessible to the F5 then the Triax Tri Link will do what you want using the existing cable as well as magic eye function
    • evoy2k2
      • Aug 2013
      • 10
      The magic eye is on the tv in the bedroom and a white cable connected to aerial socket. The tv downstairs the white cable was also connected to aerial socket and screwed into back on original sky box at the back.
      • digicon
        • 8261
        The it will still work with the item i linked you too.
        • evoy2k2
          • Aug 2013
          • 10
          Ok. Thanks for your help bud
          • evoy2k2
            • Aug 2013
            • 10
            Will i need anything else with this or just buy it as it is ?
            • digicon
              • 8261
              It comes with everything you need apart from a Scart Lead which you will need to connect the F5 to the Tri-Link
              • evoy2k2
                • Aug 2013
                • 10
                Ok, thank you
