I coulnt find the answer on here but im crap a searching so it may of been discussed lots of times ,i've found the cause and thought it might help others
After a bit of search i came to the conclusion it was a firmware issue ,I managed to update the firmware but it still re-booted..After F'ing about for a few hours i discovered it only happened when i connected the sat feed.
This was a new install and found i had 1 of the cable strands touching the inner core of the sat feed, which the box dosnt like.I actually had it touching in a few places.
So if your box is in a reboot loop try removing the sat feed first before reflashing the firmware
nyck
nyck
