help skybox f5 no channels
  • xtrabbia1974
    • 10
    hi
    ive had a skybox f5 for about 5 weeks now and everthing was fine
    i went on holiday last week and came back yesterday and now all the channels come up saying scrambled
    i can only get 1,2,3,4
    can any one help how to get it back up and working
    many thanks
  • scotty1965
    • Jul 2013
    • 116
    hi you will have to put the latest channel list on again ! make sure u back up first
    • P&D
      • 2686
      Did you turn your router off while you where a way ?????
      goto menu/network settings/ethernet setup/make sure DHCP is set to on....if it's already on turn it off...apply....reboot the box.....then go back & turn it on.....apply ...reboot the box see if that sorts it out....
      If not menu/ccam settings/manage/see if you have a green tick/& is it online or offline
      • Hadron
        • 2102
        Eh? You only normally have to update your channel list when channels change transponders.
        I don't think every single channel changed transponders while xtrabbia1974 was on a weeks holiday. LOL.
        • xtrabbia1974
          • 10
          hi many thanks for your reply
          ive check everything youve said and the ccam setting is offline but there is a green tick
          ids there anything i can do
          • xtrabbia1974
            • 10
            ive already done a new channel update
            still no joy
            • wortho
              • 144
              just check your network connections on your box menu, press apply . noticed sometimes it goes off on my f5 when i update channels list, and check your sat signal to make sure its strong
              • scotty1965
                • Jul 2013
                • 116
                HI yes i only suggested the channel update because i was watching mutv yesterday when mine all gone of scrambled only FTA was working so i rebooted my router and f3 but still no joy so backed up then put latest chan list on so they are back on now so it worked for me !
                • xtrabbia1974
                  • 10
                  hi mate
                  yes it says offline
                  does that mean i need a new ................Refresher course on reading the ...................
                  • P&D
                    • 2686
                    The answer is yes also edit your post would be good
                    The 2 words at the end should not be there if you have read the rules
