Hi :) Can i run 2 skybox,s via 1 sat dish via a dual cable connector
This topic is closed.
  • minelab
    • Jun 2011
    • 89
    Hi Can i run 2 skybox,s via 1 sat dish via a dual cable connector
  • j4g3d
    • Dec 2010
    • 253
    Yes you buy a quad LMB for example and then you can run 2 cables.
    • minelab
      • Jun 2011
      • 89
      Hi, thankyou for your reply, I,m using a skybox F3 and i,m thinking of having another 1 in another room, i understand the use of the quad lmb ...tho could i just use a standard connector inside my house that connects to the sky dish cable and has 2 outgoing connectors to it ..thankyou kindly ..
      • Hadron
        • 2102
        • DW190
          • May 2012
          • 1263
          Simple answer is No.
          Each box requires a direct feed to the LNB on the dish.
          The loop on the box or a splitter could be used but only one box would work at anyone time and the other needs to be off.
          • slugworth
            • Nov 2011
            • 1064
            you can't use a splitter with sat cable.
            read the threads on problems with more than 1 receiver on a quad lnb.
            • minelab
              • Jun 2011
              • 89
              Thankyou
