f5 Home cinema sound connection
  • Steve F
    • Aug 2013
    • 11
    Can anyone advise if f5 can play sound through home cinema box. Red white and yellow plugs produce time dubbing sync between speakers and TV. Thanx in advance for any info.
  • speedfreak70
    • Aug 2013
    I have mine connected to my AV Amp via HDMI and can cofirm that I get the DD 5.1 from the F5
    • Steve F
      • Aug 2013
      • 11
      I have the HDMI direct to TV so pic & sound are in sync. If connect to & play thru home cinema , HD/3D quality is compromised? and the dubbing sync is all over the place. So if I connect HDMI direct to TV and connect red & white speakers to home cinema, I get good quality pics but lag in the sound. I think the sound quality is 5.1 its just a timing issue. Thanks for your post Speedfreak70 cheers mate.
        I am afraid you cannot get 5.1 audio through the analogue out ( Red & White ) on any box just stereo, 5.1 is only available through either Optical/spdif or HDMI
        • Steve F
          • Aug 2013
          • 11
          Thank you for the technical clarification
          • cactikid
            • 12017
            thats the best bit when you look at picture on rear of box.
            24) Digital audio output: S/PDIF by coaxial and optical(optional);
            even a microscope cant find it and you wonder why the box is cheap =compromise
              No problem but that is probably the main issue you are trying to marry up an analogue sound signal with a pure digital picture signal.
              Have you tried through the Amp the Red/White audio and then just the Yellow Video signal into the TV, I know not ideal but this will rule out the Digital/Analogue connection problem
              • Steve F
                • Aug 2013
                • 11
                Given the two alternatives I think I'd prefer HD picture quality over 5.1 sound.... shame really. As Cactikid pointed out COMPROMISE. & as we all know "COMPROMISE IS A SIGN OF WEAKNESS" you really do get what you pay for. Finally out of interest is there a box that offers HDMI & Digital audio output: S/PDIF by coaxial and optical cable?
                  If you specify a budget of what you want to pay i am sure you will get some suggestions of different receivers available
                  • Steve F
                    • Aug 2013
                    • 11
                    Thanks for all your advise
                    • cactikid
                      • 12017
                      some of the older stuff i have is coaxial but the modern vu have all got spdif ports,god i miss my 7-1 ,and bugger you say i have one of each.
