s9 rebooting
  • fkhan786
    • 10
    s9 rebooting
    Hi, I have an original openbox s9. It keeps rebooting on HD channels, can someone please help me to sort it out.Thanks.
  • DOUGALMCD
    • May 2011
    • 3229
    Try a new channel list. If still the same you may have to reflash firmware.
    • fkhan786
      • 10
      Thanks, You don't happen to have a working channel list that you wouldn't mind sharing?.
      • Hadron
        • Nov 2012
        • 2102
        It might also be worth checking the capacitors on the PSU board. Those boxes are quite old now & the cheap caps used on the PSU are prone to failing.
        C19 is the usual suspect on these models. If it is bulging/leaking then it needs replacing.
