Hotbird ON SKyBOX F5?
  • ismbutt
    • Aug 2013
    • 19
    Is it possible to watch hotbird(13`E) satellite channels from skybox F5 ?
    my skybox f5 is set on eutelsat 28A (skyuk) channels list working very nicely !
    i wonder if its possible and if i watch on that what should i do ?
    Thanks...
  • sattv5
    • May 2013
    • 376
    Im assuming you have a fixed dish at 28 east.
    So the options are another dish pointing at 13 east or a motorised dish setup
    • badboy1965
      • 191
      yes you can watch 13 east,you DO need a motorised setup and you can watch most of Europe,there,s not just over priced sly up in the heavens.
      • ged47
        • Apr 2013
        • 81
        slylnb.jpg Or buy this set up for 34quid and line the lnbs up with the sats you wanna hit. Patience is needed for this install if doing yourself.
        Smile don?t frown, Look up don?t look down, Believe in yourself, Don?t let yourself go, Just be who you are And let your life flow.
        • ismbutt
          • Aug 2013
          • 19
          thanks very much every one ...but how will i install the hotbird satellite on my skybox f5 as i am newbie ...thanks it would be great guys...
          • Mysteriousguy
            • Aug 2012
            • 56
            Mate, get a dual LNB, this will pick up Hotbird and Astra fo you. You wont need another dish.
            Cheers
            • ismbutt
              • Aug 2013
              • 19
              Cheers
              But how will i get hotbird satellite and channel list of hotbird on my skybox f5 as it just got only eutelsat 28A preset satellite and channel list on it? please help...thanks
              • Hadron
                • 2102
                Cheers
                A dual LNB generally means that the LNB has 2 outputs, just like a quad LNB means 4 outputs. It won't allow you to watch 13e & 28e. If you mean a monoblock, I don't think they are available for 15 degrees seperation.
                A second LNB on a bracket is only really suitable if you have a dish bigger than a $ly zone 1 mini dish.
                • Hadron
                  • 2102
                  If you cannot find a channel list for Hotbird, you can add your own satellite parameters manually.
                  In the installation menu, select "satellite list". Press green button (Add). Give it a name & enter Longitude (013.0E). The DiSEqC & motor settings depend on how you are going to set up your dish (2 LNB's or motorised).
                  • ismbutt
                    • Aug 2013
                    • 19
                    ohhh thats good thanks mate...for helping me lot...
                    • ismbutt
                      • Aug 2013
                      • 19
                      thanks every one really you guys help me lot thanks..
