New Stupid Person Here
  • iqraj
    • Aug 2013
    Hi everyone.
    So I got a new Skybox F3, and my uncle showed me how to add and edit channels manually. It already had a channel list, but I didn't like it and wanted to make it more to my liking and decided to change it. So what I did first was to go to the satellite channel list (Sky UK), this is the only one I had. Then I started going through all the channels and making a list of what I wanted and checking which ones were working and stuff. After I was done with that I decided to start changing stuff and that when I ****ed up. I selected Delete All Channels (I know i'm stupid) and everything went away. There was no channel in the Satellite channel list or the favourites one. But I still had the Sky UK satellite in the satellite settings and I did a blind search and got channels back.
    My issue here is that before when I was browsing through the whole satellite channel list there were a lot more channels than what I have now. The channels do work but the older list had some channels that I wanted which I cant find now.
    Can someone pleasee help me????
  • mahrkpat
    • Jun 2012
    • 510
    What channels are looking for? Channels get replaced, renamed and just disappear all the time if you looking at a old channel list one of this has more then likely happened. To check for the latest changes and what channels are available to you check here: KingOfSat or LyngSat.
    • Hadron
      • 2102
      Originally posted by iqraj
      ...My issue here is that before when I was browsing through the whole satellite channel list there were a lot more channels than what I have now. The channels do work but the older list had some channels that I wanted which I cant find now...
      Doing a blind scan should give you every single channel that is available from the satellite it is pointing at, so it's a bit odd that you had a lot more channels before than you have now.
      • iqraj
        • Aug 2013
        Thanks for replying guys... I actually did another preset scan on the satellite and got almost all the channels. But I have another question. If I for instance upload AJ's Sky UK channel list and then I decide that I don't want some of the favourites categories, How do I delete it??
