no signal
  • jackado
    • Aug 2013
    • 11
    no signal
    hi guys need some help please set up my skybox f5 yesterday can anybody tell me why some channels are saying there no signal
  • seangraves
    • Sep 2012
    • 275
    hi mate could be number things first which channels stating no signal ?,,,,then checdk cables sat side ie is dish corretly aligned up ..have you got ya speacial bit ,,,if thets in b ox check ya dhcp is turned on in menu ,networks ,let us no soon as thanks
    • jackado
      • Aug 2013
      • 11
      hi sean its the really channel and channels with the same frequency
      • hammers2009
        • Jun 2012
        • 106
        How many boxes are set up on the dish ? ... Had this one I had to get a new dish just for the living room as I had 4 boxes on my other one all real sky box worked ok when putting in my F5 didn't work ... Got a new dish all working ok now
        • jackado
          • Aug 2013
          • 11
          hi mate do i have to use the loop on the back of the f5 box. oh i had 2 sky boxs
          • hammers2009
            • Jun 2012
            • 106
            What you using the loop for ?
            • jackado
              • Aug 2013
              • 11
              im not just asking if i had to use it
              • P&D
                • May 2010
                • 2686
                If you have 2 boxes connected at the same time
                box 1 takes away the signal from the 2nd box also if you have the official box connected...
                Disconnect the loop & try each box on a single feed one at a time.....if everything ok like this then the loop is the problem,,,drop of signal strength.
                • jackado
                  • Aug 2013
                  • 11
                  hi pd i have a skybox f5 dowstairs and an official sky box up stairs do you think this has somthing do do with the signal strength
                  • illmatic
                    • Aug 2013
                    • 11
                    If they're both running off the same dish, why don't you try disconnecting the official box from the satellite and then trying the f5?
                    • jackado
                      • Aug 2013
                      • 11
                      ok now
                      i have disconnected the official sky box seems ok now cheers
                      • digicon
                        • 8261
                        If your going to use the official receiver as well take a look at this: http://www.digital-kaos.co.uk/forums...signal-334336/
