Weird freezing while scrolling through favourites
  • illmatic
    • Aug 2013
    • 11
    Hi all,
    Just a quick one really, not sure if anyones experienced this before but I can't find anything on the forum anywhere. Basically whenever I hit the favourites button on the remote and start scrolling through groups, the picture in the background ends up scrambling and then restarting again after a short while, I've taken a video of it to make it clearer to understand, does anyone know if it could be a firmware issue etc? Please check the youtube link below and let me know your thoughts
    IMG 8701 - YouTube
    Edit: I'm running AJ's latest channel list and software version 3601HD_27_03_2013_0794
  • DW190
    • May 2012
    • 1263
    Originally posted by illmatic
    Hi all,
    IMG 8701 - YouTube
    Not suprised scrolling like that. As you move from one fav to another the box is preparing to change. Its common so stop trying to brick ya box.
    • illmatic
      • Aug 2013
      • 11
      No I was just trying to recreate the problem, I don't normally scroll like that obviously, it will just happen while scrolling normally.
      • sattv5
        • May 2013
        • 376
        It looks like the firmware is corrupted. Back up any gifts etc and reinstall the firmware from here: SkyBox | SkyBox (This one 2013/03/28 SKYBOX F5 F3 M3 - Upgrade YOUTUBE, Weather,Fix SAT List)
        After the firmware is installed install your channel list that you want
        then on the remote select Menu > Factory Settings > Select Yes > Then Press Blue
        The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order and not scrambling when going through the menu, put back your gifts and change your settings to suit.
        • darcu5
          • Jun 2011
          • 944
          alot of them do that, just select the channel you want to watch and it will work again, not like ya can watch much with the favs list stuck in middle of the screen.
          • DW190
            • May 2012
            • 1263
            Which brings me to the question of why do folk want to change the boot logo which they only see for a couple of seconds on boot up.
