f5 or f5s whats the difference
  • mickydibble
    • 2166
    hi people just a quicky what if any is the difference between F5 AND F5S , just a new version or any extras ? cheers micky
  • BrunoJ
    • Jul 2013
    • 141
    To be honest on the official skybox website the only difference is the LCD display the F5 was green and the F5S is now Blue. can't see any other difference
    • paulinter
      • Apr 2010
      • 178
      i herd the f5s uses the better receiver, think its a sharp one in the f5s, other than that i aint sure
      • bbb_uk
        • 429
        Just checked Yojiatech website and only difference is the display.
        Personally, I would stick with F5 only because it's been around a little while now so problems ironed out whereas the F5S is new so it may have problems.
        • paulinter
          • Apr 2010
          • 178
          Yes my f5 is working just fine. I read that the s type has a sharp tuner. Supposedly better than the previous f5. . Anyway I like my f5 its cheap and cheerful
          Sent from my GT-I9100 using Tapatalk 2
          • spaghettilover
            • Aug 2013
            ciao, F5S has a better remote control...firmware is not the same as F5...
            • delasalle2012
              • Aug 2013
              I must read the Forum Rules: http://www.digital-kaos.co.uk/forums...rules-2/#post2
              Discussions about cardsharing are not allowed, including, but not limited to, cccam, gbox, mbox, etc
              Last edited by digicon; 25 August, 2013, 00:07. Reason: Please read the Rules Regarding this subject matter
              • paulinter
                • Apr 2010
                • 178
                Where has anyone of us mentioned what your are referring to in your message. Why put a message like that when not one of us has mentioned what you say. Strange
                • Panther785
                  • Aug 2012
                  • 79
                  they are the exact same box with just different remote and new casing tbh casing is same
                  • DW190
                    • May 2012
                    • 1263
                    If you read the post carefully you will see that it has been edited so what you are referring to has been removed because it breached the forum rules.
                    • paulinter
                      • Apr 2010
                      • 178
                      my post wasn't edited. Using Tapatalk it doesn't say it has been edited. Still no mention by any reply on this thread to the banned text. Well i can't see it anyway. . Never mind. Enjoy
                      • DW190
                        • May 2012
                        • 1263
                        delasalle2012 had his post edited and banned material removed.
                        Sent from my Dell-1525 which does show edited posts.
                        • paulinter
                          • Apr 2010
                          • 178
                          Cheers dw190. I thought it was our posts. I can't see that it's been edited on my phone. Confusion over with .
                          • intel
                            • Apr 2010
                            • 128
                            I think the new remotes for the F3S / F5S are a step backwards, a lot of the of the buttons are white in colour with like
                            a blue insert / writing which is very very hard in see, and even more so in low light..........someone should have seen that these
                            are most likely going to used with in a low lite room...ie: your front room in the evening with low lighting levels.
                            EDIT: There are lot of issues on the F3 / F5 that needed to be addressed before the remote, like the Wifi connection and the EPG
                            ...sort them you have might have a great box, rather then a cheap box!!
                            • DW190
                              • May 2012
                              • 1263
                              The remote controls, although different in looks do exactly the same and either the new or the old will work on both boxes. They are both cheap to buy on ebay so if anyone has a preference it will cost less than a fiver ror the one of your choice and the one you dont like will do for a spare.
                              One thing I will say is that both remotes are quite well built and rarely go faulty. Other than those chewed by dogs, I have revived a couple by just boiling the psb in water and drying in fan oven.
