skybox f5 clone?
  • Kristo32
    • Sep 2012
    • 22
    skybox f5 clone?
    hi,
    can anyone tell me a quick and easy way to tell a skybox f5 clone?
    also, what exactly is a clone and whats bad about them??
  • stavros67
    • May 2013
    • 81
    Originally posted by Kristo32
    hi,
    Network Local Setting - 6666 should access another menu
    • Kristo32
      • Sep 2012
      • 22
      yes it does and i use that menu....im unsure what you mean? box works fine i just worried that if i have a clone its somehow worse than an original but it works fine and i dont even know if it is a clone!?
      • mahrkpat
        • Jun 2012
        • 510
        In some clone boxes when original firmware upgrade was made after a some time the clone got bricked i.e stopped working, recover method and clone firmware had to be used to get the box working.
        • DW190
          • May 2012
          • 1263
          hi,
          To check if its a clone you only need to look at the remote control.
          An original should have on the back a gold coloured QC sticker. (these can get peeled off)
          Also remove the battery cover and at the top of the opening it should have the word SKYBOX moulded on to the plastic.
          • gilvey
            • Apr 2014
            • 113
            Which remote are you referring to?
