no signal sent to tv on F3 box
  • tgvirus99
    • Jul 2013
    • 9
    ok so iv just been away for a few weeks and I unplugged the box whilst I was away come home power it up it counts to 100 flashes a few times the says 0001 like its on channel 1 but I don't get a signal to the TV (like iv not got the hdmi plugged in) iv tried putting it on another hdmi on the TV and also used a known working hdmi cable but still nothing.. my TV doesn't have scart so I cant check the output via that cable type unless I move it upstairs.. does anyone know what's going on here the box is only 2 months old.. iv reset it loads of times powered it down with button on the back unplugged it ect so I think iv covered most of the obvious tests thanks in advance.
  • seangraves
    • Sep 2012
    • 275
    move wot up stairs ?//ave you got a dvd player /video player or summet to test the tv downstairs ...try resetting ,,skybox factory reset it and put lateset firmware on it ps save ya best bits to usb first ,,,,,,if still no good try it at a mates house ///
    • DW190
      • May 2012
      • 1263
      TV not having a scart makes no difference as the F3 doesnt have a scart.
      Could be the V.Format has been pressed.
      Easiest way to check is to use the red white and yellow leads, in fact one will do to connected to the video socket. Then you should be able to go into the settings and check the video format output is on a compatable one.
      • durasoft
        • 57
        Hi tgvirus,
        If you have put it on 0001 and you have lets say Sattv5 or AJ's channel list installed then their will be no picture. As blank channel's are inserted from 0001 to 0100
        Try putting in 101 as that then hopefully should bring up BBC1.
        If not try what DW190 said and could well be the fact that the V-Format has changed.
        Just test by attaching the (Video) Yellow RCA plug from a Red/White/Yellow Composite lead. And putting your TV on the appropriate A/V Channel.
        Like DW190 say's hopefully should get a picture to enable you to check the HDMI properties in the menu.
        Hope we have pointed you in the right direction to help you sort your issue out
        Regards Tony
        Humax FoxSat-HDR
        Great HD/SD Box with 500GB HardDrive
        Manhatton HH-120 42E-30W
        Triax 88cm 0.3db
        SKYBOX F3
        HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
        Intel Core i7 [email protected]
        MSI R7970 Twin Frozr Boost Edition
        • Hadron
          • 2102
          Originally posted by tgvirus99
          ok so iv just been away for a few weeks and I unplugged the box whilst I was away come home power it up it counts to 100 flashes a few times the says 0001 like its on channel 1 but I don't get a signal to the TV (like iv not got the hdmi plugged in)...
          Have you actually tried changing channels, to make sure the box hasn't locked up?
          As mentioned above, use a phono (RCA) lead to connect the yellow socket on the box to the composite input on your TV.
          @durasoft...AJ's list starts at 0001, whereas sattv5's $ly numbered list starts at 0101.
          • tgvirus99
            • Jul 2013
            • 9
            thanks for your fast response I will get a phono rca lead and test that as I don't actual have one in the house anymore all the TVs are connected via hdmi and I don't even have a old one knocking about.. ok the TV is fine Xbox ps3 and blu ray player all work fine what I meant by I don't have a scart was that I didn't think it had a rca input but on looking again I see that its mixed in with the component hd connections. (also this is what I meant by taking it upstairs I do have TVs with hdmi and scart rca upstairs) I did try and change the channels blind (Fav ok right ok) and it changes on the display to 0002 I do have ajs channel list on whan it boots up and it counst to 100 it usaly displays the blue skybox logo I don't even get that on..
            • tgvirus99
              • Jul 2013
              • 9
              ok I have a dodgy connection to the hdmi on the box, I fixed it with a bit of spit and cardboard thanks for all your help
              • Hadron
                • 2102
                LOL. I have seen quite a few boxes on Ebay with non-working HDMI ports. Perhaps you could sell your idea on Ebay!
                • cactikid
                  • 12017
                  just shows you people like buying crap boxes with all the problems that are associated with them
                  • Hadron
                    • 2102
                    ...but where's the fun in buying a box that works perfectly! LOL.
                    • durasoft
                      • 57
                      Ebay can be a great source for boxes, especially if some other people charge the earth for these.
                      Cloning of these boxes is surely non profitable unless you pay more than ?49.34?p
                      Have had 4 boxes now with no problems from ebay. I must be lucky then.................
                      Humax FoxSat-HDR
                      Triax 88cm 0.3db
                      SKYBOX F3
