  • Hangman2
    • Apr 2012
    • 20
    HI please can someone tell me what is the best open box to buy to receive full sky channels uk.
    also do I need to card share?
    its all very confusing on the net.
    please as much info as possible will help
    thank you in advance.
  • DW190
    • May 2012
    • 1263
    All the info has been repeated many many times. You just have to read starting with the stickies at the top.
    • durasoft
      • 57
      Also do I need to card share?
      Hi Hangman2,
      Openbox/Skybox, everybody will have their favourites. In my case I use a Skybox F3 with Sattv5 Channel List Installed.
      You don't have to CS if you have a card but if you had a card then you wont be looking here
      CS is the way to go, but be careful as per rules discussing CS on here is NOT ALLOWED.
      If you have an old mini dish up and you want to use it then connect your Openbox/Skybox to it.
      Install one of the well organised Channel List's (which can be downloaded from this site) from a USB Stick. There's info on how to do it.
      Plug your Receiver via Ethernet lead into a router for CS purposes. Again there is info on the site on how to setup DHCP on your receiver.
      To benefit from ALL the channels you will need what we call a gift from a CS server.
      This is a little line of info that can be uploaded via USB Stick (cccam.cfg) or by manually inputting it in the cam menu.
      Once you have that setup you can sit back and enjoy.
      Surely some other nice guy's might add something I've maybe missed.
      But again as above mentioned, there is lot's of info out there regarding this subject.
      But there is area's we can't discuss as per rule's. But it's not all to complicated
      Hope this help's.
      Regards Tony
      Humax FoxSat-HDR
      Great HD/SD Box with 500GB HardDrive
      Manhatton HH-120 42E-30W
      Triax 88cm 0.3db
      SKYBOX F3
      HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
      Intel Core i7 [email protected]
      MSI R7970 Twin Frozr Boost Edition
      • Hangman2
        • Apr 2012
        • 20
        Thank you Durasort,
        i will try and give this a go and hopefully get sorted.
        any more info like links for software would be great.
        thank you for your help
