CAN ANYONEE PUT ME IN RIGHT DIRECTION FOR THE HOMEPLUGS THAT ARE USED FOR THE F5 SKYBOXES ,,,,IE LINK TO CHEAPEST UN BEST TYPE THANKS
BEST HOMPLUGS TO USE FOR F5 SKYBOX
Tags: None
ON NETWORKS PL200-199UKS 200 Mbps Powerline Adapter Kit
Buy ON NETWORKS PL200-199UKS 200 Mbps Powerline Adapter Kit | Free Delivery | Currysinformation given is to be used for educational purposes only
If It Ain't Broke Don't Fix It -
I have used the Solwise Homeplugs all round my house, works great and never had any problems with the network.Comment
I also use solwise and have not problems but they're not cheap. In fact, prob one of the expensive ones I've seen around.
I need another set for a friend so I would like to know if anyone has these On Network homeplugs referred to by Joe and if they're are any good?Comment
Those Currys ones look cheap but ive used these recently and they work fine. Bit dearer but can confirm they work on F5. 7dayshop 200Mbps Mini Powerline Ethernet Network Adapter - TWIN PACK - 7DAYSHOP.COM Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
Good price Nige but 200s are plenty the 500s would be a waste.not used these but tempted at 500mbps TP-Link PA411KIT AV500 500 Mbps Powerline Adapter - Twin Pack: Amazon.co.uk: Computers & Accessories
I have used them without any problems. The instruction leaflet is rubbish though. It's as if it was written for a different model. However, I found that they were just plug 'n play. They worked first time without any button pushing to set them up.
I found that when I had both Tx & Rx on extension leads, they both showed a red light (rather than green). I thought this meant that there was no connection, but they still worked perfectly. Perhaps it just means that the s***d is reduced. As I say, the instruction leaflet doesn't mention this.
They are also available on Ebay:-
ON NETWORKS PL200-199UKS 200 Mbps Powerline Adapter Kit - New | eBayComment
Do the instructions by any chance specify what, if any, specification they adhere to, like HomePlug AV, HomePlug AV2 ?I have used them without any problems. The instruction leaflet is rubbish though. It's as if it was written for a different model. However, I found that they were just plug 'n play. They worked first time without any button pushing to set them up.
I found that when I had both Tx & Rx on extension leads, they both showed a red light (rather than green). I thought this meant that there was no connection, but they still worked perfectly. Perhaps it just means that the s***d is reduced. As I say, the instruction leaflet doesn't mention this....
ThanksComment
The installation guide doesn't mention this. It can be downloaded from here:-
Their webside does say thay they are Homeplug AV1 compliant:-
On Networks | Powerline 200 Home Network AdaptersComment
