timer record f5 skybox
  • kurrdogg
    • Jul 2013
    • 23
    is there anyway possible to set up timer record on f5 skybox ./
    if so how do u do it
  • andy4
    • 1125
    yeh, menu ok>timer settings ok>ok timer mode once or daily > timer service to rec > wake up channel (channel you want to rec, put it the channel you want to rec before doing all this saves going through all channels > wake up date (date you want to rec)then set your channel time to rec & duration (NOT what time it goes off) and save then exit out, you can leave box turned on or on standby
    WIGAN ATH the BLUE BRAZILIANS
    DWSTADIUM the theatre of SCREAMS
    <<<<--------if i've been helpful hit the Thanks button
