f3 box and sky plus box
  • mark9111
    • 8
    is there any way of connecting both boxes with out getting a new lmb splitters etc
  • DW190
    • May 2012
    • 1263
    Splitters on Sat are a none starter.
    If you have Sky + chances are you have a quad lnb already. Just run another cable from the dish to your F3. Some of the lnb's have a sliding cover that obscures the view of the conneting sockets. If the end of cable fittings appear hidden the cover will slide up to reveal them.
      your going to need the inline diode fix for the F3 to connect both at the same time
      • mark9111
        • 8
        [QUOTE=digicon;2086426]your going to need the inline diode fix for the F3 to connect both at the same
        where do i get those and how much we looking at
        • DW190
          • May 2012
          • 1263
          skybox fix | eBay
          • mark9111
            • 8
            am i right in saying that will fix the no signal when its put thru a splitter new to all this ??
            • DW190
              • May 2012
              • 1263
              Not at all. You cannot split a satellite signal like you can with cable (V*rgin) or DVB (Freeview).
              Every feed must be direct to the lnb unless your in a communal block of flats.
              The No Signal Fix is a voltage fix csused by some some conflict between horizontal and vertical frequencies. (An thing more on this is beyond me).
              • Hadron
                • 2102
                What type of LNB do you have on your dish at the moment? How many connectors does it have on it?
                Is it a $ly dish (wider than it is high) or almost circular (slightly higher than it is wide)?
                • mark9111
                  • 8
                  not sure will look in morning at let u know all i know its been up there 3years
                  • DW190
                    • May 2012
                    • 1263
                    All that could have been said in one word!
                    OVAL
                    You can see that this is a quad lnb.
                    • Hadron
                      • 2102
                      OVAL
                      [ATTACH=CONFIG]218955[/ATTACH]
                      ...but both types of dish are oval. That's why I asked whether it's the width or the height that is longer.
