OPENBOX S6000 HD v CLOUD IBOX
  • skybandit
    • Aug 2013
    • 81
    I'm on the point of ordering an OPENBOX S6000 HD but my searches for the best deal seem to suggest that it is identical to the CLOUD IBOX, in fact an EBAY ad uses both names for the same box.
    The specs for the two boxes seem identical.
    Any enlightenment would be appreciated...
  • DW190
    • May 2012
    • 1263
    Just the name is different but make sure you get one with a fan.
    • kaisar1
      • Aug 2009
      • 462
      has anyone got a backup for there ibox or s6000 receiver.
      Im having alot of problems with greenscreen and freezing
      • mahrkpat
        • Jun 2012
        • 510
        What image are you using? OpenPli by all accounts is a good stable image for the openbox 6000.
        How To Flash An Image on Openbox S6000HD
        OPENBOX S6000HD HELP & SUPORT BY PROMO7UK @ LINUXSAT
        1.download image of your choice.!! vix , openpli , blackhole ,etc or use files that come with this package,!!
        2.Usb memory stick must be formated to fat32 important,!
        3.open rar files supplied you will see folder "vuplus" move this complete folder to the root of
        your usb memory stick...
        4.plug usb into your reciever "making shure the power is OFF before you do so,!!"
        5.once usb plugged into your S6000HD Reciever. turn the power switch to "ON" Position,
        NOW WAIT.. YOUR USB WILL FLASH IF IT HAS A LED ON IT. TO SHOW BEING USED,!!
        6.your new box image will automatically load .. now. this could take 1-3 minutes depending on image used,!
        7.when your front light on box goes PINKY colour it means its updating image.!
        8.after 40-50 seconds light will then goto RED this means formatting Flash please wait,,
        9.after this it will go PINKY again,, THIS IS WRITING TO FLASH.
        10.ONCE COMPLETED FULL FLASH INSTALL LIGHT WILL "" BLINK BLUE""
        YOU ARE NOW COMPLETE TURN OFF BOX & REMOVE USB MEMORY STICK ,!
        YOUR IMAGE OF CHOICE HAS BEEN INSTALLED.!!
        • kaisar1
          • Aug 2009
          • 462
          I installed blackhole 2.0.5 and get constant freezing. Rubbish box as far as im concerned with very little help compared to other receivers.
          No one has even uploaded a working backup. In hindsight i should have not bought this.
            I am afraid that is a problem with the clones some people get a good one and some get a bad one, I would persevere and try a different image to Blackhole until you find something that is stable for an E2 Linux box that costs around ?60 delivered from china its still worth a punt
            • kaisar1
              • Aug 2009
              • 462
              The problem with this receiver is lack of support.
              For example for vu solo, duo, dm800 alot of people have uploaded a backup image, whereas for this box no one has.
              Its for obvious reasons why they have not as they resell. However considering the potential i would have thought there would be alot more support.
                I doubt its lack of support as basically this receiver is a Vu Solo full stop which has a tremendous amount of support, As for lack of back up images why would you want to use one in the first place anyway as what image configured on one receiver may not work on your receiver anyway. As no 2 receivers are identical when manufactured, Ok some will work but is it not an ideal solution to start from scratch with a so called Clean image run the receiver bare bones so to speak to see if it runs correctly without hiccup and if so then add Plugins,cams etc... one at a time and test again until your happy you have a fully working image with everything you need.
                Personally i would never use a backup off any receiver but my own as that way i know it works as it should.
                • mahrkpat
                  • Jun 2012
                  • 510
                  I agree with digicon the cloudbox/openbox 6000 run the original images of vu+solo and there is a lot of support out there, therefore don't think of these as clones but a vu solo and look at the problems you have and I am sure someone using a vu solo would have experienced the same problem and solved them too also when you are installing things yourself you actually get to know your receiver.
                  • DW190
                    • May 2012
                    • 1263
                    These receivers are worse than women.
                    I was told PLi runs smooth but I cant get any addons to work, even loading then is a problem. Running Blackhole I dont Have a problem.
                    Even with Blackhole the Auto Bouquets from DK wouldn't work but one from another forum did.
                    Just like women bloody awkward.
                      Welcome to the wonderful world of Linux Enigma2 and the joy it brings :-)
                      • DW190
                        • May 2012
                        • 1263
                        Yes its another world even after the Dbox days.
                        • mahrkpat
                          • Jun 2012
                          • 510
                          I have found even when I download from the plugin panel sometimes it breaks something else now I look for the latest .ipk file for my image and download then use 7zip until I get to folder structure that I can ftp in to my box but before I ftp I explore and see what common files are going to be altered then make a backup from my box of it, this takes longer but also has saved me hours of trying to fix a broken plugin.
                          • kaisar1
                            • Aug 2009
                            • 462
                            blackhole 2.0.5 works perfectly up until i install cccam 2.30 from tspanel.
                            im going to have a go tonight to configure the box. hopefully goes well. wasted atleat 3/4 days on this box.
