hi there got f5v set up on one tv through scart cable can i connect another tv in next room to watch same channel if so how do i go about this ie ive got a coax cable connected to secound tv were and how do i connect this up idiots guide thanks
f5 connectin g to two tvs
Tags: None
You can get a scart that goes from 1 to 2 but the longest ive seen is about 3meters,your b better off with a wirless AV sender m8................
rf av sender | eBayI know you believe you understand what you think i said
I am not sure you realise that what you heard is not what i meant ! sigpic -
If the second TV has composite input, you could use a phono (RCA) to phono lead. There are 10m ones on Ebay:-
10m TRIPLE 3 RCA PHONO Male Plug to Plug Audio COMPOSITE Video AV Cable TV Lead | eBay
If that's not long enough, there are 15m & 20m ones too.
If you want to use the RF (coax) lead on the second TV you will need a modulator to convert the composite output of the F5 to RF:-
Dragonsat RF Modulator UHF Channel 21-69 CCTV Convert to Aerial TV Phono VHF | eBay
If you decide on a video sender, I wouldn'd get a 2.4GHz one, as they are too prone to interference. 5.8GHz ones are best.Last edited by Hadron; 14 September, 2013, 15:10.Comment
