sky card problems.
  • paul davies
    • Sep 2013
    sky card problems.
    H I bought 3 white sky cards from an Irish source on ebay but when I put the card into the receiver a message says wrong card for this type of box can anyone help.
  • darcu5
    • Jun 2011
    • 944
    what sort of box u using, allso i would of thought the card needed to be paired to a box?
    If it isn't broke, don't try fixin it..!!!
    • Hadron
      • Nov 2012
      • 2102
      If you put a white $ly card in an official $ly box, you can receive the few channels that are still FTV (such as Motors TV, Liverpool TV, & a few others).
      The problem is, it sets the region to wherever the card was registered.
      • darcu5
        • Jun 2011
        • 944
        Cheers mate, I remember now, I toyed about with a FTv years ago whilst on a learning mission.. Had to mess about a little to get pick tv.
        Have you tried them both ways up in the reader
        • digicon
          • 8261
          Has anyone actually found out if the card reader in the Skybox F3/F5 can actually read an NDS card, I know most other receivers when patched with firmware makes there card slot a multicrypt perhaps this is not the case with the F3/F5
          • sattv5
            • May 2013
            • 376
            The card reader in the Skybox F5 reads NDS cards not sure about anything else but I think it's multicrypt
            theres options in the menu to CA Slot settings.
            Settings used were:
            CA Slot Clock Setting (6.12mhz)
            Emm Allow (Enable)
            Card faces upwards and matches up with the arrow on the side of the box. You can also even put your box key in if necessary
