Hi, I am a bit new to this satellite stuff so would appreciate any help.
i recently bought an SKYBOX F5S and connected up and its all fine. however i also have SKY and wish to use that at the same time.
i read on this forum that you can create a loop from the skybox to the digi box, but obvioulsy both cant be used at the same time and 1 would have to be on stand by in order to use the other. (I am unable to draw another line direct from the satellite dish due to location and position of it)
i have done this, and the skybox f5s works nicely, however when i put it on standby and go to use the digibox... it keeps saying NO SATELLITE SIGNAL IS BEING RECEIVED on all the channels.
prior to that i have attempted to use a splitter but that makes the signal non-existent for both pretty much.
any ideas what i can do?
many many thanks in advance
, i tested with just the official $kybox and the f5 and it works fine individually (the wires are not DIY, bought from shop). i have the old school tuner (not $ky +), the signal levels on the $kybox itself is about 50% strength and 50% intensity. unless i can get a ladder which can scale up 4 floors by a side of a building, its virtually impossible for me to get another dedicated line, hence my reason for a loop.
