Skybox F5s problem, dim red light with "8" displaying on front of receiver
  • mleczus1
    • Sep 2013
    • 7
    #31
    Originally posted by Colsnr
    I got the Dull 8 problem. I found a guy advertising that he could fix this and most problems with Skybox. He would charge me ?12 if he could fix it or refund if he could not. So i posted it off to him and within a week got it back fully working again. Well worth the money as i was about to put it in the bin.
    ebay is it ?
    • Colsnr
      • Oct 2013
      • 13
      #32
      Yes it was. Can give you a link if wanted. Return postage included.
      • mleczus1
        • Sep 2013
        • 7
        #33
        Thanks. I try to find solution myself. Maybe one day someone will help.
        • plasterer
          • 1631
          #34
          All the helps there mate.just follow the instructions.......Paul
          If your Happy with the Help push the Thanx button
          PAUL
          • mleczus1
            • Sep 2013
            • 7
            #35
            Like I said did all I could with all instructions. Still no luck
            • dotcomsimon
              • Dec 2011
              • 11
              #36
              Hi,
              I'm fairly new to this, Ive had my F5S for about a month now and have had no problems whatsoever (touch wood)
              Ok, so last night I decided to unplug the F5S and take it upstairs to watch, Unplugged all the cables and plugged my upstairs cables in, turn the box on POOF! a dim 8 with red light, Then the box counts up to 100 and then flashes the dim red 8 and reboots counting up to 100 again followed by the dim red 8, It just kept looping over and over.
              I tried unplugging various cables and plugging them back in - No matter what nothing would stop it looping.
              After trawling through various web pages basically everyone seems to think its buggered so I thought i'd return it,
              Took it downstairs and without thinking plugged it back in POOF! all working again like nothing happened!
              The only thing I can think off is maybe the upstairs sockets might be overloaded, I had the box in an extension lead with laptop,tv and blu-ray player in same 4 gang extension
              My downstairs setup is very similar however the extension socket downstairs has built in surge protection (about?20 from argos) - Now I dont know if this is a solution for anyone else but it worked for me
              • Hadron
                • 2102
                #37
                dotcomsimon...when you had the box upstairs, did you try booting the box with the LNB cable disconnected?
                Sometimes a rebooting problem is caused by a short circuit in the LNB cable.
                It wouldn't have anything to do with the mains connection.
                • dotcomsimon
                  • Dec 2011
                  • 11
                  #38
                  Ah! sorry didn't realise that, no I didn't try without the LNB, I thought that because it was taken out of the back of my current working official skybox (only FTA channels) it was a case of straight swapping, Might have another go later
                  • jlcpana
                    • Aug 2014
                    I have the same problem code 8 and the dim red light, help, can not get the firmware update
                    • ColinsPlace
                      • Apr 2014
                      • 14
                      #40
                      I also now have 4 of these dead boxes - faint no 8 , can't seem to do anything , with them ?
                      • Wallace69erus
                        • Aug 2014
                        Hi
                        Hi I did this upgrade now it asking me for a pass code to get into the menus do u know wat they are
                        • mickzer
                          • Nov 2013
                          • 81
                          #42
                          Try 0000 or 6666..
                          • Hadron
                            • 2102
                            #43
                            If 0000 doesn't work, try 3327.
                            • tomjames123
                              • Aug 2014
                              • 5
                              #44
                              Hi could i have the link to the ?12 fix it dood, I've come to this last resort prior to throwing mine in the bin.
                              Regards
                              • dredlox
                                • May 2013
                                Just aquired an f5s with the same problem, tryed my power supply from my f5 and it worked... seems to be a psu issue.
                                checked the voltage of the psu i got with it and its only outputing 5v....mine 12v
