recording on skybox
  • flipuk
    • Aug 2013
    • 4
    recording on skybox
    hi ive got a skybox and ive bought a harddrive when i record i can only record staight away in other words i carnt select something that starts 2 hours later and set it to record that. is their any way of doing this?? thanks for any help
  • wortho
    • 144
    there is a timer mate, just set it to time and channel, works good mate, not at home so cant go through the process with you to do it.
    • captainglassback
      • 14
      Works very well on F5 and F5S. Menu.....System Setup.....Timer setting....1.....OK......Timer Mode on.....Timer Mode once.....Timer Service 'Record'. Set the on time and duration. Exit. STB off ie in standby. You're sorted (though check that stb has correct time!).
      • flipuk
        • Aug 2013
        • 4
        thanks alot works great
