4 feeds from one LNB, problem
  • homelyn
    • Sep 2013
    Hi I think I am right on this but just need to check.. Can I run three cables from one LNB to a legal sky+ HD box and SkyboxF5? I am getting scrambled on some channels but not on FTA. Do I need another dish to run two cables to Skybox F5? I get 72% signal strength on all channels throu skybox F5, but get scrambled after 5 mins or so. Any help would be gratefully received.Cheers
  • DW190
    • May 2012
    • 1263
    Errr. You dont have two cable going into a F5. One socket is a loop through.
    • homelyn
      • Sep 2013
      Yep, of course, silly me? But with three cables should I be able to run the two boxes .
      • DW190
        • May 2012
        • 1263
        Shoiuld run ok but there has been one or two getting voltage errors running Skybox alongside Sky+ box. Just make sure your connections are clean and tidy with no outer strands floating aound.
        • cactikid
          • 12017
          i will say no just to be different as at some stage with providers box and a skybox the no signal might show up on the skybox and its a very commpn problem,may have to change make of lnb.
          • Hadron
            • 2102
            Channels on some F5's may be affected when running on the same LNB as a $ly+ box. This usually shows as "no signal" rather than "scrambled" though.
            Try turning off the $ly+ box & checking if the channels start working again.
            If there is a problem with both boxes on at the same time then there is a fix available on Ebay (Search for "no signal fix").
            • jefro78
              • 5
              im a satellite installer, its a common problem on older lnbs. simpley upgrade to a new quad lnb and it will be fine
