I have had my skybox f5 for a couple of months now, it had a few issues of restarting itself every 10mins so I installed an old firmware which fixed the problem. I did try installing the latest firmware but the problem continued. If there is a fix for this please let me know. The problem now started a week or 2 ago randomly where the channels start scrambling alot. Now the problem is so bad the tv channel $ and fta work for a little while (5-10mins) then suddenly stop working. When I click info it says 0% signal. The SNR is around 75%. In the antenna setup its universal (9750-10750) lnb frequency and the signal intensity and quality is around 85%. I don't know what has caused the problem but it stays 0% for hours even the FTA channels don't work.
skybox f5 0% scrambled issue
First thing I would do is try another receiver on the sat feed to eliminate your receiver.I have had my skybox f5 for a couple of months now, it had a few issues of restarting itself every 10mins so I installed an old firmware which fixed the problem. I did try installing the latest firmware but the problem continued. If there is a fix for this please let me know. The problem now started a week or 2 ago randomly where the channels start scrambling alot. Now the problem is so bad the tv channel $ and fta work for a little while (5-10mins) then suddenly stop working. When I click info it says 0% signal. The SNR is around 75%. In the antenna setup its universal (9750-10750) lnb frequency and the signal intensity and quality is around 85%. I don't know what has caused the problem but it stays 0% for hours even the FTA channels don't work.
