After re-flashing the lastest image now my F5S stuck on n0CH on display??
Tags: None
Try and put a channel list on it, Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
thanks for coming back to me,
Sorry im used to the old s11 and open boxes..
how do i go about doing this..
cheersComment
Hi download a channel list..Aj's or sattv5 list to usb
http://www.digital-kaos.co.uk/forums...ml#post2104184 or http://www.digital-kaos.co.uk/forums...ml#post2043054
plug the usb in the box
menu/upgrade by usb/press remote right on the pad/upgrade misc files/choose TP_prog/click ok/press the yellow button/restart the boxLast edited by P&D; 3 October, 2013, 23:12.Comment
The wierd thing is on my display, i have no menu selection, will not respond, just an image of ironman punching the ground.
i have used image SKYBOX_F5S_3601HD_CMT_1307040584.abs..
i have save channel list to usb, but pressing anything on the remote.. no display menu is showing..just the iron man picture?Comment
The reason updating the firmware from the manufacturers website isnt working is because that has a blank channel list as well.
1 Download the Skybox Lan Tool from this post and extract the folder to your desktop
2 Put the chanel list that you want to use in the folder
3 Click on SKYBOX F4_F3_M3_LAN_TOOL.EXE and wait for it to start
4 Put the IP address that the skybox uses into where it says BOX IP and click login
5 If you don't know what the ip address is of your skybox have a look in your router
6 On the left hand side under system you should see TP_Prog.dbs click on it so its highlighted
7 The arrow in the centre should have lit up now (pointing right) click on it
8 The channel list should now upload to your box and the box should restartAttached FilesComment
Set Up?
[QUOTE=sattv5;2112722]The reason updating the firmware from the manufacturers website isnt working is because that has a blank channel list as well.
8 The channel list should now upload to your box and the box should restart[/QUOTE
How do you set this up ie; do you set the box up to the router or the computer, i am confusedComment
I am having the same problem and updating via lan tool shows I have channel numbers but no picture or menuComment
