Here we go again,lots of missing channels questions....Answers HERE
Hello all. Your help would be very much appreciated. I have the F5 and have very poor signal strength (7-32%) on a few tps. Namely for sly spts 1 HD (SD ok), BT spts HD 1&2 (SD ok), prem spts and setanta spts. All other tps fine. I use Sattv5 channel list which I have updated today. Still have problem which I have had for nearly 2 weeks. Should I reflash firmware? I have 3601HD_27_03_2013_0794 installed. What should I do to try and resolve weak signal strength. Thanks.
Wrong thread to ask on....but
This could be a number of thing's
The f5's are known for this how can i put this ..the easiest way i can think of is s**t with a capital S.....
you could try to flash the latest firmware...might help...(plz backup the box 1st)...Menu/dump by usb...then your ok to do what you want with the box...
I would check the dish hasn't moved
check the sat cable
do you have the official $ly box connected
how many boxes do you have connected to the dish
Sounds like it might be a signal drop....which need a signal fix ......check ebay....i dout it because normally only on the V-.transponders
My preference would be the box...can you check it on a mates setup to check if it works at theres....this would eliminate most of the answered above.....& point to the box
new software came yesterday for skybox F5s
SKYBOX F3S F5S 131024 Support EUROPE XML EPG view
what will this software do can anyone explaine me plz thanks
