latest channel list f3/f5
Tags: None
- [*=1]Unzip AJ's List XX-XX-XX.zip with a program such as winrar & place the TP_PROG.DBS file onto the root of your USB drive.
[*=1]In the Openbox menu delete your current channel list by going to the "Edit Channel" tab & selecting "Delete All".
[*=1]Staying in the menu navigate to the "Tools" tab then "Upgrade by USB", change the upgrade mode from "Image File" to "Misc Files" then "Select & Upgrade" & select "TP_PROG.DBS" then press yellow, if all done correctly it should begin to upgrade.
[*=1]Once the upgrade has completed restart your box & voil?!
Guide on page 1 of ajs channel list. AndyNew Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
Before you start you will need a USB stick and need Winzip or Winrar install on your PC
Go to this website
Once there, go to the section
Channel List TP PROG
Download this and save onto a USB stick
Now plug the stick in the F box
First of all go to the Menu Panel and into the Edit Chanel
Click on Delete All channels ( and delete)
Next go Tools
Click on Upgrade by USB
Where it says Upgrade Mode at top press sideways on the remote till you see Misc file
press start (OK button)
then highlight TP_prog/press ok it should put a green tick at the side
press the yellow button on the remote wait till the box does its thing
Once done press exit button on remote ( it should save settings)
Exit it completely and then reboot the box.(make sure you do this otherwise it will not be saved)
Hopefully all channels will be back.
If this is to hard for you to do, then just ignore all above and go into Installation in menu button and press Single satellite search and press scan***8230;..this will scan the whole satellite and store channels***8230;***8230;.but these wont be in favourites but in ALL***8230;( however this will also download all adult channels as wellComment
I have tried the below but am having no luck.
When I follow the below steps it says,
"No file"
Do I need to have completed a satellite scan first? I am trying to be cautious in order to not brick my box.
Any help would be appreciated.
Go to this website
Next go Tools
have a look here at Sattv5 channel list see if it's what your after http://www.digital-kaos.co.uk/forums...1/#post1980897Comment
