was wondering if some one can answer me this
  • hood128
    • Oct 2013
    • 14
    ive got my normal slybox under my tv and my f5s box on top is there any way or any thing i can buy just that when some wants to record they use sly box then i have to keep unplugging ariel cable to slybox then once they finnished recording there tv i have to put ariels back in my f5s box is there any sort of adaptor cheers
  • Hadron
    • 2102
    There are a couple of options.
    Use a switch box to switch one of the feeds to either the $ly+ box or F5s... F Type Satellite Cable A-B Switch FREE P&P - UK SELLER | eBay
    ...or you could use the loop through on the F5s box. Connect one of the feeds to the F5s box LNB input, & then connect a lead from the Loop through to one of the LNB inputs on the $ly+ box. You will need to make sure that whichever box you don't use is in standby if you use this method.
    In both cases, one sat feed is left permanently connected to one of the LNB inputs on the $ly box.
    The switch boxes are also available in Maplin for a couple of pounds more.
    • hood128
      • Oct 2013
      • 14
      thanks for quick reply mate ive just orded one of them switiches of ebay link you gave im still new at this will i need to buy some more cable so both boxe are linked through tit cheers mate
      • Hadron
        • 2102
        You will need a couple of short F-type to F-type cables.
        Something else that I forgot to mention, is that if you have spare ports on your LNB, you could run another cable from the dish to the F5s, so that you don't need to swap leads at all.
        • hood128
          • Oct 2013
          • 14
          just orded of same site 2x 2m f type cables cheers for info glad i joined this site all new to me but other half likes her slybox so she can record her tv but i like to use me f5s box for sport but have both on top of each other running of one dish just that when i use my f5s box i have to turn slybox off to stanby is that right
          • scotty1965
            • Jul 2013
            • 116
            yes put your slybox on standby thats what i do !
            • .: JaCkPoT :.
              Retired Sat TV Addict
              • 5607
              A note for anyone else with a similar dilemma
              Best bet for the easiest possible installation would have been the loop out from the skybox.
              ___________________
              In the good old days, I had
              DM800s HD
              Openbox S10
              TM500
              DM500s
              90cm FortecStar dish
              Maxx 110cm Dish
              Technomate 2300 Motors
              • bbb_uk
                • 429
                That has drawbacks as I used that method and occasionally I would get no signal on certain channels from the F5 even though $ky box was on standby.
                I found I had to wait a while or just unplug the loop from F5 to $ky to correct it.
                At a guess I was thinking maybe it was the $ky box updating EPG, something internally, or a clash of somekind between F5 and $ky despite $ky being on standby.
                In the end, I ran a separate feed from LNB to F5 and have no problems at all now and don't have to worry about suddenly losing signal on F5.
                • .: JaCkPoT :.
                  • 5607
                  no, i mean connect the LNB to the skybox/openbox and running the loop out from that to the sky receiver, that would give the skybox/openbox priority on signal.
                  ___________________
                  DM800s HD
                  Openbox S10
                  TM500
                  DM500s
                  Maxx 110cm Dish
                  • bbb_uk
                    • 429
                    That was my setup but it made no difference. Occasionally, I would still lose signal on Skybox/openbox despite $ky receiver being on standby. Only way of correcting it was waiting for it to correct itself or remove the loop cable from my F5 to $ky receiver.
                    As I said it would correct itself but this could sometime take minutes and sometimes bit longer and as I said I think maybe the $ky receiver itself was either updating EPG or something.
                    • .: JaCkPoT :.
                      • 5607
                      Ah i see, thats odd. Must be the higher power drain from the receivers.
                      ___________________
                      DM800s HD
                      Openbox S10
                      TM500
                      DM500s
                      Maxx 110cm Dish
                      • bbb_uk
                        • 429
                        In a perfect world and ideally the F5 when switched on should ensure signal is blocked/stopped via the loop feature so this would mean F5 take priority when on and any other receiver wouldnt be able to use the input from the F5.
                        Like I said as a guess the $ky receiver although still in standby is doing something (like EPG updating) that it needs signal for and with F5 being on it causes a conflict and F5 loses with some channels.
