Hi guys, trying to record 2nite but for some reason it saying Limit: CAN Not Record! Theres like 400GB space left on the Hard drive so its not full. Any ideas?
Skybox F5 Not Recording
We need more info if you need help, are you using USB stick or external hard drive??
You also need to format your USB to ntfs format before it will work.Tools owned: Hammer, Chisel, Crowbar, Punch, Chainsaw, Cutter and Brain!!!
Note:All information given is to be used for educational purposes only and should not be taken seriously. -
Ensure the formatting is correct. You can check the current format by connecting upto a PC and looking at the drive properties. Or if you have a defrag program, that should also tell you.
___________________
In the good old days, I hadDM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Maxx 110cm Dish
Technomate 2300 Motors
sigpicComment
I can read now when I highlited, you need to format the drive that should solve your problem!!Tools owned: Hammer, Chisel, Crowbar, Punch, Chainsaw, Cutter and Brain!!!
Note:All information given is to be used for educational purposes only and should not be taken seriously.Comment
