F5s No Signal all channels
  • andylad
    • Oct 2013
    Hi can some help , this is driving me crazy, I have an F5s downstairs ,f5 in one bedroom & very recently purchased 5fs in second bedroom all running off quad lnb(ex sky kit)
    for some reason since I purchased the 3rd box , I get no signal on all channels on latest box, this has also passed on to box in other bedroom. If I unplug one of the box's & leave for an hour , it works fine, however it would seem I'm unable to use 3 box's at same time. I'm looking to purchase a forth box but as you can see I'm struggling . Any help pointers would be a great, thanks. Andy
  • P&D
    • 2686
    Hi sound like a drop in the signal power...
    are you running 3 cables from the LNB one to each box.....
    LNB could be faulty or you need a signal booster
    • lee11168
      • Feb 2011
      • 217
      the sky box f5 is known for this they drain the lnb power
      • sattv5
        • May 2013
        • 376
        You can either go down the route of fitting the skybox LNB fixes that they sell on ebay:
        No Signal Fix s9 s10 s11 s12 F3 F5 V Polarized channel selection Openbox Skybox | eBay
        Or the better option of replacing the LNB, I know the Zinwell (J4L) model works perfectly with 4 Skyboxes. So anything after that model should work fine as well
        ZINWELL QUAD LNB MK4 FOR SKY+ / FREESAT+ | eBay
        • andylad
          • Oct 2013
          Thanks people, its not the no signal fix as its all channels not working when I power up 3 box's, for the sake of ?5 I'll order a new lnb ,
          ill let you know, really appreciate your responses
          • genam
            • Apr 2013
            • 176
            I have 3 feeds from my LNB..1 to the F5 and 2 to my Sky HD+ box...mine works fine so does sound like your LNB could have died
            • P&D
              • 2686
              genam i will give you 10/1 you stick another F5 on your setup & you'll get the same probs
              the F5's drain the power so much from the lnb its frighting
              • .: JaCkPoT :.
                Retired Sat TV Addict
                • 5607
                Quick suggestion, would an amplifier not work?
                Yes i know it costs a similar amount but another person who reads this with this sort of issue may have an amplifier lying around (like i do )
                ___________________
                In the good old days, I had
                DM800s HD
                Openbox S10
                TM500
                DM500s
                90cm FortecStar dish
                Maxx 110cm Dish
                Technomate 2300 Motors
