Help please. How to resore from backup?
  • yermansam
    • Sep 2012
    • 13
    I tried to upgrade my firmware on my skybox f3 and somehow got it wrong. All the premium channels remained scrambled. Fortunately (I hope) before I attempted this I backed up my box using these instructions.
    "select 'TOOLS'
    select 'DUMP BY USB'
    on new window, make sure 'DUMP MODE' reads 'Image file.(*.abs) and select start
    do it again, but this time use remote arrow keys to select 'Misc Files'
    Press ok on 'SELECT AND DUMP' and place a tick by everything in there, then press yellow button on remote 'DUMP'
    you can then remove stick and copy all your backed up info to pc
    Its good practice to do this everytime you change something on box."
    I then tried to restore my box using the the above method only choosing to "upgrade" instead of "dump. However the premium channels still remain scrambled!!
    What am I doing wrong? Wish I hadn't bothered now:-(
  • tshuma
    • Jan 2012
    • 20
    Check to see if you have DHCP turned on.
    Also go and check if your line is online.
    • P&D
      • 2686
      Do both as tshuma says above
      check..DHCP menu/network settings/ethernet/switch on apply/reboot box....
      check if your active...menu/C****s/manage/highlight whats in there & press ok (you should now have a green tick)/reboot box
      job done
      Just a quick one for both above a quick refresh of the Forum Rules might be a good idea before posting again (line 6 comes to mind)
      • slugworth
        • Nov 2011
        • 1064
        i think the gift is stored in an area of flash not normally saved by your method.
        • P&D
          • 2686
          It is on the F3 box if he ticked all the files before then downloaded them
          not to sure about the image file tho
          • yermansam
            • Sep 2012
            • 13
            It was the DHCP. It was off!! Many thanks Tshuma and P&D
