Channel order after update
  • tayyab95
    • Jul 2013
    • 79
    everytime I update my channels I have to manually move around all my channel categories and it takes so long, is there any way quick way to keep the channel order and do an update, ive tried the backup but never works.
  • sattv5
    • May 2013
    • 376
    The way to get The favourites under the correct headings is to load the default Database:
    On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
    The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order
    • .: JaCkPoT :.
      Retired Sat TV Addict
      • Aug 2008
      • 5607
      why not use channel lists uploaded here by some members? Saves time and theyre organised
      ___________________
      In the good old days, I had
      DM800s HD
      Openbox S10
      TM500
      DM500s
      90cm FortecStar dish
      Maxx 110cm Dish
      Technomate 2300 Motors
      • JAMES78
        • Aug 2009
        • 15
