Why am getting only AJ Channel list Skybox f3??Any other Sattellite?
  • Zizzo
    • Dec 2012
    • 56
    Hi,
    Actual am still confused and I don't know what to do, actual at the moment I have downloaded AJ Channel list and everything working perfect, but when I try to scan another satellite am still getting the same channel which I have from AJ Channel list (Astra) so what could be the problem here?Am still confused and I need your help guys because I really need to get Italian channels, missing HOTBIRD really need it and am missing channels like JS SPORTS 1-10 and other Italian channels, so now am getting only AJ Channel list that's all..
    Also outside I have motorised dish, before I start using AJ Channel list I was getting all the channel but now I can't get HOTBIRD.
    Any advice will appreciate!!
  • Hadron
    • 2102
    Originally posted by Zizzo
    Hi,
    If you are still getting channels from 28.2e when you scan then your dish hasn't moved. Perhaps it needs a squirt of WD40!
    • Zizzo
      • Dec 2012
      • 56
      The dish is moving outside and is going to different direction so am no too sure what is the problem. any idea or what should I do??
      • sexysam
        • Oct 2008
        • 209
        Have you downloaded AJ's bouquets for motorized dish or have done a scan of the other satellite once you have got your dish to lock onto them?
        • sattv5
          • May 2013
          • 376
          By default only Astra 28a is selected.
          1 Go into the menu on the remote
          2 Then to satellite list
          3 Press OK on every Satellite that you want
          4 Now press exit
          5 Scroll down to multi sat search
          6 In this menu select search, and your box will search for channels on the satellite you previously picked
          • max10
            • 51
            Hi guys, I currently have standard dish and using AJ UK channel List 28.2.
            Which other satellites 28.2 can I view with normal dish, where can I obtain AJ channel list with outside 28.2 channels?
            • P&D
              • 2686
              If its a fixed dish none
              • P&D
                • 2686
                4 Now press exit
                plz beware the F3 will only hold 4-5 sats then the memory is full
                • Zizzo
                  • Dec 2012
                  • 56
                  I have not downloaded the AJ's bouquets for motorized dish, where can I download it?? also I have done all of that but still am getting the same channel, Example if I scan HOTBIRD am getting ASTRA channel why why?? and outside the dish is moving...
                  • Zizzo
                    • Dec 2012
                    • 56
                    4 Now press exit
                    I have done that but still am getting ASTRA channel instead of HOTBIRD any moree help please??
                    • P&D
                      • 2686
                      Do as above...
                      step 4 make sure Usals in set to on....on all the sat's you want
                      • Hadron
                        • 2102
                        Can I just clarify something, as this is confusing me. LOL.
                        If you select $ly (Astra2 28.2e) & scan, then you get the correct channels.
                        If you select Hotbird (13e), your dish physically moves, but after scanning it still scans the channels on 28.2e???
                        • P&D
                          • 2686
                          Hadron it's a 4m dish ...sorry couldn't help myself
                          sounds strange...either the dish is not moving....which its sounds like...... it can't be moving if it still scans the same sat....or the box is not setup correct...or sorry Zizzo user error
                          • Zizzo
                            • Dec 2012
                            • 56
                            Originally posted by P&D
                            Do as above...
                            I have done that as well, and still am getting ASTRA channels and not HOTBIRD, what could be the problem??Very strange and am confused as well.
                            • Zizzo
                              • Dec 2012
                              • 56
                              Yeah that's correct, that is what am getting very strange. Don't know what to do.
