f5 lost gift
  • slaughterman
    • Oct 2013
    f5 lost gift
    hi,can anyone help me,ive done a full factory reset and not done a back up,i think ive lost my gift conection,wolly,i have been able to get my cams back by putting in the 6666 code in the menu setting,but all channels are coming up scammbled,is there anyway of sorting the box,or should i shoot it with my shotgun and see if that helps
  • andy91
    • Aug 2010
    • 3583
    You have lost it see your supplier we cant help on here even and if there was a way its against the forum rules, Andy.
    • P&D
      • May 2010
      • 2686
      there is only 2 things you can do....
      1. check DCHP is switched on ....menu/network settings/erthernet/switch DCHP on/apply.....then reboot the box...
      then
      2. check if you know what is active....menu/C***m/manage/make sure there is a green tick at the end of the item in there/if its there....reboot box
      if you do/can both above....bob's your uncle...box sorted
      • Hadron
        • Nov 2012
        • 2102
        Unless you ticked any additional selections in the pop up box that appears when you select Factory settings, then your gift line should still be there.
        But, as P&D suggests, your DHCP would have defaulted to "OFF" so will need to be switched back to "ON".
        Also your local time setting may need to be set to UK.
