Can anyone help? I've lost my favourites after rescan to retrieve lost channels and I was wondering if it's fixable. I have a skybox f5
Favourite lists lost
hi im no expert but I also lost favs while doing a rescan and after trying everything I changed usb stick and that did the trick for me so might be worth a try -
"My Favourites are all wrong since I loaded your list how do i fix them ?
The way to get The favourites under the correct headings is to load the default Database:
On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order, AndyNew Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
Absolutely magic worked like a charm."My Favourites are all wrong since I loaded your list how do i fix them ?
Thank you
GroverComment
