plz plz help me skybox f5s
  • pakaro1986
    • Oct 2013
    • 13
    im put new list channel from my skyboxf5s and some channles with signal and some channles with not
    can help what problem of that?
  • P&D
    • 2686
    turn the box off at the wall ....reboot the router.....wait 5 mins'.....switch the box back on & check the channels
    • pakaro1986
      • Oct 2013
      • 13
      its the same problem no signal
      example channel no signal bt sport
      • P&D
        • 2686
        What channel list have you used ???
        • bigade1
          • Oct 2013
          • 340
          When you're tuned into BT Sport press the INFO button on your remote 3 times and it will show the Transponder details of the channel. If it does not say 12574/H/23000 then either you're using an old channel list or you haven't updated the list properly. Can you confirm this?
          • pakaro1986
            • Oct 2013
            • 13
            this channel list from http://www.digital-kaos.co.uk/forums...ularly-358725/
            AJ's List 15-10-13.zip
            • bigade1
              • Oct 2013
              • 340
              Can you confirm it says 12574/H/23000 on BT Sport as asked in my previous post?
              • pakaro1986
                • Oct 2013
                • 13
                yes its 12574/H/23000 on BT Sport
                signal entre 46 et 53
                if i scan progamm not found
                • bigade1
                  • Oct 2013
                  • 340
                  Thanks, we can rule out the list then. The channel list on your box is up to date. It seems to be a signal problem which could mean a number of things i.e. checking your connections, condition of your cable, position of your dish, possibly lnb. The ideal way of checking would be to try your box in someone else's house.
                  • pakaro1986
                    • Oct 2013
                    • 13
                    yes it's 12574/H/23000 on BT Sport
                    signal between 46 and 53
                    if i scan program not found
                    • P&D
                      • 2686
                      can you get the same channel but the SD one...try sattv5 list see if that fix's it
                      • pakaro1986
                        • Oct 2013
                        • 13
                        its same the
                        im change cable and lnb and new list channel but bt sport no signal
                        • kevinjm
                          • 13
                          bt sport
                          read somewhere if you use ajs list make sure its the 4th of the 10 then you should ger bt sport back on
