A lot of users are getting the " Mismatch File " error when they are upgrading their Skyboxes to get the latest software. This error generally occurs if their particular box is what's known as a " clone " box or in other words a box not made by the official manufacturer. The official software downloads for the Skyboxes are available from here:
If you do get the " Mismatch File " error then it's a reasonable assumption that your box is a " clone " box and you should try downloading the software from either of these sites:
Or:
Download / Software / Skybox F3/F5/M3_Shenzhen Yojia Technology Co., Ltd.
It's a matter of trial and error which site provides the correct software but one of them should work. Once you've ascertained which one works for your particular box then you should make a note of that site and continue to use it for any future updates.
In the unfortunate event that you do brick your box i.e. it becomes dead, then you should refer to this thread:
This is a guide only and any upgrade attempts are done at your own risk. Please bear in mind, the general accepted rule is :
" If it isn't broke - don't fix it! "
Or:
