UK channel list size
  • fac51
    • 103
    HI peeps.
    could someone please help me out here reguarding the multi ready made SKY uk channel list available here to download (TP_PROG.dbs).
    Some are 60kb in size and others are 1024kb.
    Why the big differance in size and why can I only use the larger 1024km ones when the majority are the smaller size of 60kb
    Ive tried about 6 differant software versions including the most recent from yojiatech web site but still i can only use the larger files and not the smaller which seem to be more plenty full on here.
    I have a skybox F3.
  • inbed79
    • Oct 2013
    • 13
    i dont undersand what your are saying the sky cs list that works like a sky remote ie press 106 you get sky1 press 110 you get gold
    if you are on about these type they have to be a little larger as youhave to make some dummy chans to pack out so they chan numbers work out
    the ajs list can be smaller but not that much
    are you trying to load a ziped/winrar file
    if you get what iam saying see my list
    • bbb_uk
      • 429
      The correct filesize of Skybox/Openbox is 1meg (1024 KB).
      Depending on where you're getting the 64KB file from it could be simple case of its zipped/compressed. These type of files normally end in .rar, .zip, etc.
      • DW190
        • May 2012
        • 1263
        I have a skybox F3.
        It appears the files you are trying without success require unzipping or un raring.
        Download winzip or 7zip then you can extract them to use.
