Back Up F5s
  • yamaha1000
    • Oct 2013
    Back Up F5s
    Hi guys, can someone tell me how to back up an F5s? Can I do it onto a USB and what menu is it on the box? I have a seriel cable for the PC if that helps. Cheers
  • SdTM
    • Oct 2013
    • 36
    Hello,
    you our only need a USB
    connect usb usb to your skybox and do the following -
    go to menu-tools-dump by USB
    change dump mode to "misc file"
    Click on "select and dump"
    Select "TP_PROG.dbs" so it has a tick next to it then press yellow to dump onto USB,
    that at will backup your channel list
    To backup your Server/Gift whatever you want to call it just select the "CCcam.cfg" or newcamd.list file instead of "TP_PROG.dbs".
    to back up the entire image choose image in the menu then dump to usb
    The required backup should now be on your usb stick, make sure to move it to your pc or be careful not to delete it.
    • yamaha1000
      • Oct 2013
      many thanks worked a treat
